[geos-devel] GEOS 2.1.1 sprintf Compile Error
Fri Jan 28 00:07:22 EST 2005
Folks,
I get the following error building geos 2.1.1 with gcc 2.95.4:
/bin/sh ../../libtool --mode=compile g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers -I../../source/headers/geos
-I../../source/headers -DGEOS_VERSION=""2.1.1""    -g -O2 -c -o QuadTreeNodeBase.lo `test -f
'../index/quadtree/QuadTreeNodeBase.cpp' || echo './'`../index/quadtree/QuadTreeNodeBase.cpp
  g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers -I../../source/headers/geos -I../../source/headers
-DGEOS_VERSION=2.1.1 -g -O2 -c ../index/quadtree/QuadTreeNodeBase.cpp -Wp,-MD,.deps/QuadTreeNodeBase.TPlo  -fPIC -DPIC
-o .libs/QuadTreeNodeBase.o
../index/quadtree/QuadTreeNodeBase.cpp: In method `class string geos::QuadTreeNodeBase::toString() const':
../index/quadtree/QuadTreeNodeBase.cpp:149: implicit declaration of function `int geos::sprintf(...)'
I can work around it by include <stdio.h> at the top of the file.  Are there
any objections to my committing such a change?  I'm not sure if there is any
bad karma in doing so, or if we ought to just replace sprintf() with something
more modern.
Actually, there are a couple other files I ran into with the same problem.
Best regards,
