[geos-devel] JTS/GEOS performance
strk at refractions.net
Fri Jan 28 07:19:55 EST 2005
Some time ago I've been researching about GEOS performance
problems as related to JTS. Attached is a shapefile and an .xml
test you can use to compare the two.
JTS does not support buffers tests, so you'll need to use another
method for that. I used JUMP, which reports computation time.
Well. The operation is a buffer(polygon, 2000).
JTS: 18 seconds
GEOS: 574 seconds (9 minutes, 34 secs)
GEOS computation keeps the CPU pretty busy (98.2-99.8%)
and takes up to about 170 MB of ram
JTS seems to use 3 threads, the bigger using at most 80%
of CPU, but most of the time far below that point.
JUMP reports 104MB committed, but I'm not sure about the meaning.
For GEOS, valgrind reports (with buffer 500):
malloc/free: 2982697 allocs, 2982697 frees, 924407212 bytes allocated.
How much do you think this wild allocation negatively influence the
poor performance of GEOS ?
--strk;
