[geos-devel] JTS/GEOS performance
Martin Davis
mbdavis at VividSolutions.com
Fri Jan 28 13:12:07 EST 2005
Thanks for the detailed reply, Martin.
Your comments about how objects are handled probably reflects a
too-close adherence to the Java origins of the code. Or, they could
just be plain failure to take advantage of efficiencies possible with C.
In either case, it seems like a substantial revision of the code base
will be required.
Regarding your comment about the inefficiency of computing intersects as
! Disjoint, I'm aware of this issue and am starting to take steps to
address it in JTS. I agree that for intersects at least a faster
general implementation is possible. I'd be interested in hearing some
details of your implementation - for instance, how do you make the
intersection detection efficient?
As for the other named spatial predicates, I'm not sure I see as much
opportunity for optimization. This is due to the fact that most of the
others require precise knowledge about how the boundary of one geometry
interacts with the exterior or interior of another geometry. This in
turn requires knowledge of *all* intersections, not just whether an
intersection exists. This might be optimizable for particular cases of
geometry types, but you then have the situation of needing to specify
numerous different algorithms for different pairs of geometry types.
This is why the initial JTS work focussed on coming up with a general
algorithm for computing all predicates in the same way.
But it would be great if you see any opportunities for faster
implementations in particular cases, and if you could post details so
all can benefit.
Martin Davis, Senior Technical Architect
Vivid Solutions Inc. www.vividsolutions.com
Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046
> -----Original Message-----
> From: Chapman, Martin [mailto:MChapman at sanz.com]
> Sent: January 28, 2005 9:47 AM
> To: GEOS Development List
> Subject: RE: [geos-devel] JTS/GEOS performance
> I studied the GEOS code and here is my opinion:
> 1. GEOS makes multiple copies of the coordinates during many
> operations rather than storing the points once and then
> passing pointers.
> 2. GEOS has a complicated object model that makes objects
> for everything. To calculate most spatial operations and
> relationships requires the construction and destruction of
> many many objects.
> 3. The DE9IM implementation makes mistakes like intersects =
> !disjoint. That requires a full scan of all points in a poly,
> whereas a straight intersect algorithm will return faster
> most of the time because it can exit after it finds the first
> intersecting point. In general, I think there should be
> optimized algorithms for each spatial operation/relationship
> rather than trying to calculate the full de9-im matrix. You
> can keep the matrix, just change the way it gets populated
> behind the scenes.
> 4. When doing operations on point arrays, make functions
> that takes pointers to arrays and just pass the pointers in
> from the geometry classes. Currently, when you call a
> function like intersects GEOS makes copies of points and a
> slew of objects for each geometry operation.
> For a comparison, we tried to use geos with postgresql and
> used the POSTGIS intersect method. We found it very slow so
> we wrote our own user-defined intersect function. Ours is
> 109 times faster on a million plus geometries. That means a
> one second query for us takes GEOS 109 seconds.
> Martin
> From: Martin Davis [mailto:mbdavis at VividSolutions.com]
> Sent: Friday, January 28, 2005 10:12 AM
> Poor alloc performance would be my first guess for the
> performance difference. I would think Java is pretty
> optimized for memory allocation, since it relies on it so heavily.
> I think one standard approach to handling slow malloc is to
> build a sub-allocation layer. This would be made a bit
> easier in GEOS, since almost the allocation done inside
> geometry methods is released at the end of the method. You
> could probably even dispense with the free calls as long as
> you were operating in the memory pool. (One messiness that
> would need to be thought out is how to support exposing the
> various components such as tree indexes and noding while
> still allowing a custom allocator to be supplied. Or you
> could just forget about this and just support access through
> geometry methods. This is getting pretty far from the
> philosophy of JTS though...).
> I'm not enough of a C expert to know if this is the best
> route to pursue
> - anyone have any other ideas?
> > From: strk at refractions.net [mailto:strk at refractions.net]
> > Sent: January 28, 2005 4:20 AM
> > To: geos-devel at geos.refractions.net
> > Subject: [geos-devel] JTS/GEOS performance
> > Some time ago I've been researching about GEOS performance
> problems as
> > related to JTS. Attached is a shapefile and an .xml test
> you can use
> > to compare the two.
> > JTS does not support buffers tests, so you'll need to use another
> > method for that. I used JUMP, which reports computation time.
> > Well. The operation is a buffer(polygon, 2000).
> > JTS: 18 seconds
> > GEOS: 574 seconds (9 minutes, 34 secs)
> > GEOS computation keeps the CPU pretty busy (98.2-99.8%)
> > and takes up to about 170 MB of ram
> > JTS seems to use 3 threads, the bigger using at most 80%
> > of CPU, but most of the time far below that point.
> > JUMP reports 104MB committed, but I'm not sure about the meaning.
> > For GEOS, valgrind reports (with buffer 500):
> > malloc/free: 2982697 allocs, 2982697 frees, 924407212 bytes
> > allocated.
> > How much do you think this wild allocation negatively influence the
> > poor performance of GEOS ?
> > --strk;
> > geos-devel mailing list
> > http://geos.refractions.net/mailman/listinfo/geos-devel
