[geos-devel] Ready for 2.1.2 ?
strk at refractions.net strk at refractions.net
Tue Jun 7 10:49:05 EDT 2005
I've upgraded GCC to 3.4.4 and had success building GEOS
on FreeBSD 4.2. Did anyone handle to compile GEOS with
gcc < 3.0.0 ? (so we can document the requirement)
--strk;
On Tue, Jun 07, 2005 at 10:05:02AM +0200, strk at refractions.net wrote:
> On Mon, Jun 06, 2005 at 08:46:39PM -0700, Paul Ramsey wrote:
> > OK, compiles and runs the XMLTester fine under OS/X 10.4.1
> > I'm good to go. Any other test results from other platforms (windows
> > anyone? slowaris? freebsd? OS/X 10.3?)
> No luck on freebsd 4.2 with gcc 2.95.2 (very very old).
> The problem seems to be with stringstreams: unavailable sstream
> header - including strstream unavailable ostringstream type.
> If anyone have similar problems and possibly a solution I'd
> change sstream usage with something else.
> --strk;
> > cvs -d :pserver:cvs at postgis.refractions.net:/home/cvs/postgis co -r
> > branch-2-1 geos
> > cd geos
> > ./autogen.sh
> > ./configure
> > make
> > cd source/text
> > ./XMLTester
> > Paul
> > Paul
> > On 6-Jun-05, at 2:07 AM, strk at refractions.net wrote:
> > >We'd like to release GEOS 2.1.2, a bugfix and performance
> > >improvement work.
> > >Changes since 2.1.1:
> > >- Segfault fix in Point::isEmpty
> > >- Mem Leak fix in OffsetCurveBuilder::getRingCurve
> > >- Bugfix in LineSegment::reverse
> > >- Added multipolygon buffering test in source/test/testLeaksBig
> > >- Ported JTS robustness patch for RobustLineIntersector
> > >- Removed useless Coordinate copies in OverlayOp::mergeZ()
> > >- Avoided throws by IsValid on invalid input
> > >- Stricter C++ syntax (math.h=>cmath, ieeefp.h in "C" block,
> > >ostringstream
> > >  instead of sprintf)
> > >- Better support for older compilers (Polygonizer::LineStringAdder
> > >friendship)
> > >- Removed useless Coordinate copies in CGAlgorithms::isOnLine()
> > >- Added support for polygonize and parametrized buffer tests in
> > >XMLTester
> > >- Fixed support for --includedir and --libdir
> > >- Fixed Z interpolation in LineIntersector
> > >- Handled NULL results from getCentroid() in XMLTester
> > >- Segfault fix in (EMPTY)Geometry::getCentroid()
> > >- Made polygon::getBoundary() always OGC-valid (no LinearRings)
> > >- Input checking and promoting in
> > >GeometryFactory::createMultiLineString()
> > >- Segfault fix in GeometryEditor::editPolygon()
> > >Did anyone other then me test the code yet ?
> > >It is accessible using the branch-2-1 tag of CVS.
> > >Any test or bug report is highly appreciated.
> > >Thanks
> > >--strk;
> > >_______________________________________________
> > >geos-devel mailing list
> > >geos-devel at geos.refractions.net
> > >http://geos.refractions.net/mailman/listinfo/geos-devel
