[geos-devel] Re: [postgis-users] Error compiling PostGIS + GEOS
strk at refractions.net strk at refractions.net
Mon Jun 13 12:42:17 EDT 2005
Auch! On my system that's only a warning :(
It is probably due to CXXFLAGS being appended CFLAGS, which
inherits default value at build time.
Try changing line 206 of lwgeom/Makefile (first CFLAGS occurrence)
CFLAGS += ...
To:
CFLAGS = ...
--strk;
On Mon, Jun 13, 2005 at 09:24:54AM -0700, Chip Masters wrote:
> OK, we downloaded the 2.1.2 GEOS package, and tried
> installing PostGIS 1.0.1 w/ it, and now I'm getting
> this trying to rebuild PostGIS:
> cc1plus: Unrecognized option
> `-Wdeclaration-after-statement'
> cc1plus: Unrecognized option `-Wold-style-definition'
> cc1plus: Unrecognized option `-Wendif-labels'
> make[1]: *** [lwgeom_geos_wrapper.o] Error 1
> make[1]: Leaving directory
> `/cyc110/scratch/postgis-1.0.1/lwgeom'
> make: *** [liblwgeom] Error 2
> [root at cyc11 postgis]# ls
> There are only 2 options for using GEOS in the
> Makefile.config, and I am certain they are set
> correctly.
> Any help is greatly appreciated.
> Chip Masters
> chip_masters at yahoo.com
> --- strk at refractions.net wrote:
> > The upcoming 2.1.2 GEOS version should have fixed
> > this,
> > you can try downloading the "branch-2-1" branch from
> > CVS.
> > --strk;
> > On Wed, Jun 01, 2005 at 10:51:46AM -0700, Chip
> > Masters wrote:
> > > PostGIS users,
> > > I recently tried compiling the PostGIS 1.0.1
> > package
> > > together with the GEOS 2.1.1 package, following
> > the
> > > instructions for doing so found in the
> > README.postgis
> > > document included in the PostGIS distribution. I
> > am
> > > using the following versions of gmake and gcc:
> > > GNU Make version 3.79.1
> > > gcc (GCC) 3.4.2
> > > I am trying to install on RedHat 7.3, w/ the
> > > 2.4.20-18.7bigmem kernel. I get the following
> > error:
> > > > ../index/quadtree/QuadTreeNodeBase.cpp:149:
> > > `sprintf' > undeclared (first use this function)
> > (Each
> > > > undeclared identifier is reported only once for
> > each
> > > > function it appears in.)
> > > > make[2]: *** [QuadTreeNodeBase.lo] Error 1
> > > > make[2]: Leaving directory
> > > > `/cyc110/scratch/geos-2.1.1/source/geom'
> > > > make[1]: *** [all-recursive] Error 1
> > > > `/cyc110/scratch/geos-2.1.1/source'
> > > > make: *** [all-recursive] Error 1
> > > Can anyone help?
> > > Thanks in advance,
> > > Chip Masters
> > > __________________________________
> > > Discover Yahoo!
> > > Get on-the-go sports scores, stock quotes, news
> > and more. Check it out!
> > > http://discover.yahoo.com/mobile.html
> > > _______________________________________________
> > > postgis-users mailing list
> > > postgis-users at postgis.refractions.net
> Yahoo! Mail Mobile
> Take Yahoo! Mail with you! Check email on your mobile phone.
> http://mobile.yahoo.com/learn/mail
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
