[geos-devel] Re: isOnLine optimizations + ABI compatibility
strk at refractions.net
Sat Jun 25 05:41:55 EDT 2005
On Fri, Jun 24, 2005 at 12:03:59PM -0700, Martin Davis wrote:
> > I've been profiling Union operations.
> > It seems the most time-spending function
> > is Envelope::intersects() called by
> > LineIntersector::computeIntersection()
> > called by CGAlgorithms::isOnLine for every segment of a given
> > CoordinateSequence.
> Strk, I've come up with a fix for this problem which should avoid any
> isCovered tests at all, for cases where it's not required (e.g. for the
> union of polygons).
> I've commited this to JTS. (I assume you can determine the changes from
> via diff, right?) Can you retry your performance tests and let me know
> if this makes a difference?
Yes, a BIG difference. New timings are comparable between buffer(0)
and incremental Union() implementations:
Envelope::intersects calls reduce from
430875985 to
10010718
Now the problem is understand whether it is possible to use the
patch in geos-2.1 without breaking ABI. I'll research on this
and in postgis connector before going back to GEOS/JTS profiling.
Thanks! (timings follow)
Timings:
Classic geomunion (geos-2.1)
real 2m25.230s
user 2m20.337s
sys 0m0.527s
Classic geomunion, Martin JTS patches (geos-2.1)
real 0m58.692s
user 0m56.113s
sys 0m0.392s
Classic geomunion (geos-head)
real 1m40.458s
user 1m36.724s
sys 0m0.454s
Classic geomunion, Martin JTS patches (geos-head)
real 0m43.015s
user 0m41.207s
sys 0m0.352s
Buffer(0) geomunion (geos-head)
real 0m43.845s
user 0m41.906s
sys 0m0.358s
