[geos-devel] Making exceptions inherit from std::exception
Mark Coletti
mcoletti at gmail.com
Wed Mar 9 21:41:23 EST 2005
It's a good idea to have all exceptions inherit from std::exception.
std::exception classes provide a consistent exception handling
interface. For example, I generally have the following in my code:
try
foo();
catch( std::exception & e )
const char * msg = e.what(); // debugger probe point
throw e; // rethrow so hopefully better handled upstream
That way I can generally quickly figure out what has happened in the
debugger. Otherwise I'm left with this:
catch(...)
// um?
So then it's back to unwinding the stack from the debugger. Not hard,
just tedious.
I've made the changes to my local GEOS CVS; I've attached the diffs to
possibly be patched into the main branch.
Cheers,
Mark
I'm taking reality in small doses to build immunity.
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20050309/75aeee60/diffs.obj
