[geos-devel] Error Compiling GEOS CVS and Snapshot File Missing
Darren Houston
dhouston at beyondcompliance.ca
Tue May 10 00:45:40 EDT 2005
Hi strk,
I updated GEOS with your patch, started compiling and it almost made it all
the way through. Your patch did fix the one problem I had. A new error was
thrown that looked like it was an issue with the gcc compiler, so I upgraded
to a more recent version (3.4.3 from 3.3.5). GEOS CVS compiled fine. I've
included my compiler error below for future reference.
Thank you for your help,
Darren H.
example.o(.gnu.linkonce.t._ZNSbIhSt11char_traitsIhESaIhEE12_S_constructIPhEES4_T_S5_RKS1_St20forward_iterator_tag+0x4e):
In function `unsigned char* std::basic_string<unsigned char,
std::char_traits<unsigned char>, std::allocator<unsigned char>
>::_S_construct<unsigned char*>(unsigned char*, unsigned char*,
std::allocator<unsigned char> const&, std::forward_iterator_tag)':
/usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.5/include/g++-v3/bits/basic_string.h:311:
undefined reference to `std::char_traits<unsigned char>::copy(unsigned char*,
unsigned char const*, unsigned)'
collect2: ld returned 1 exit status
make[1]: *** [example] Error 1
On May 9, 2005 01:17 pm, strk at refractions.net wrote:
> I didn't get errors with GCC 3.4.3, anyway this patch should
> fix it, please try:
> Index: source/headers/geos/WKBWriterT.h
> RCS file: /home/cvs/postgis/geos/source/headers/geos/WKBWriterT.h,v
> retrieving revision 1.3
> diff -U2 -r1.3 WKBWriterT.h
> --- source/headers/geos/WKBWriterT.h 29 Apr 2005 17:40:36 -0000 1.3
> +++ source/headers/geos/WKBWriterT.h 9 May 2005 19:17:00 -0000
> @@ -113,5 +113,5 @@
> template<class T> void
> -WKBWriterT<T>::write(const Geometry &g, T &os=outStream)
> +WKBWriterT<T>::write(const Geometry &g, T &os)
> outStream = &os;
> strk;
> On Mon, May 09, 2005 at 11:53:00AM -0600, Darren Houston wrote:
> > Hello everyone,
> > It's been about 6 months since I've updated my PostGIS and GEOS to the
> > latest and greatest (CVS) to play with. I grabbed GEOS from the hourly
> > snapshot from the website, configured and started to compile. An error
> > was thrown;
> > ../../source/headers/geos/io.h:272:29: geos/WKBWriterT.h: No such file or
> > directory
> > Indeed, this file is missing. So, I grabbed the latest CVS source (17:00
> > hours GMT, May 9), ran autogen.sh, made sure WKBWriterT.h was in the
> > source (which it was), configured and started to compile. An error was
> > thrown;
> > In file included from ../../source/headers/geos/io.h:272,
> > from Geometry.cpp:28:
> > ../../source/headers/geos/WKBWriterT.h:115: error: invalid use of member
> > ` geos::WKBWriterT<T>::outStream'
> > WKBWriterT.h is giving me problems. I looked at WKBWriterT.h, but I'm not
> > a C++ programmer, so no blazing mistakes jumped out at me.
> > My environment is as follows;
> > gcc (GCC) 3.3.5 (Gentoo Linux 3.3.5-r1, ssp-3.3.2-3, pie-8.7.7.1)
> > GNU Make 3.80
> > Let me know if you want any more info.
> > Hope this was usefull,
> > Darren H.
> > geos-devel mailing list
> > geos-devel at geos.refractions.net
> > http://geos.refractions.net/mailman/listinfo/geos-devel
