[geos-devel] Re: WKB parser
strk at refractions.net strk at refractions.net
Fri May 13 11:30:05 EDT 2005
On Fri, May 13, 2005 at 09:14:23AM -0400, dblasby at openplans.org wrote:
> strk,
> JTS has an "equalsExact(Geometry,Geometry)" method and a
> "equalsExact(Geometry,Geometry, tolerance)".
> I'm pretty sure that GEOS has at least the former.
> I'm not 100% sure if its 2d or 3d (I assume its 3d, but I could be
> wrong).
I'm making some tests, the tolerance argument is mandatory with
GEOS, but code seems broken (a simple comparison of a point
in and out WKB returns false...).
Anyway, thanks for the point, I'll at least fix that, and
possibly use it for testing WKB.
--strk;
