[geos-devel] GEOS C API Suggestions
Sat Oct 15 23:13:29 EDT 2005
Folks,
Circa Sept26 I grabbed GEOS for an effort to integrate the C API
with OGR (instead of the C++ API).  I have gotten back to that
project today and gotten the updated OGR to build but there are
still unexplained crashes.
I haven't tracked that all down, but I do have a few suggestions I
thought I should make while I have stuff fresh in my mind.
 1) The Distance operation is missing and would be quite useful.
 2) Why is the WKB buffer of type "const char *" instead of "unsigned
     char *" or some similar "byte oriented" type?
 3) Within geos_c.h I think it should use produce it's own extern "C"  {}
     around all the declarations if included by a C++ module.
 4) I think the GEOS C entry points should be DLL exported.
 5) I think it would be nice to provide entry points to directly
     create and destroy geometries however that is not really critical.
     However, I found it odd that calls like GEOS_GetNumCoordinate()
     and GEOSGetNumGeometries() were provided when no calls
     to get coordinates or geometries were provided.
I appologise if my comments are out of date.
Best regards,
