[geos-devel] building geos 2.2.1 using Visual Studio 8
strk at refractions.net
Mon Apr 3 07:07:14 EDT 2006
I'm not personally interested, but I'm sure others are :)
I'd be more comfortable if someone else takes the
responsibility to keep win32 scripts up-to-date, as I'm
not able to test them.
--strk;
On Sun, Apr 02, 2006 at 03:44:12PM -0600, Charlie Savage wrote:
> Strk,
> The project files checked in with GEOS 2.2.2 don't actually work last
> time I checked. I have a project file for VC++ 8 that works, plus adds
> in compiling for the C library. I can provide a patch if you're interested.
> Charlie
> strk at refractions.net wrote:
> >We're about to release 2.2.2.
> >Could you test current candidate from CVS ?
> >You should access the 'branch-2-2' tag.
> >TIA
> >--strk;
> >On Sun, Apr 02, 2006 at 05:24:53PM +0200, Bart van den Eijnden (OSGIS)
> >wrote:
> >>Hi list,
> >>I've got a problem trying to compile geos 2.2.1 (which is part of
> >>Mapserver's buildkit for Windows) using Visual Studio 8:
> >>RepeatedPointTester.obj : error LNK2001: unresolved external symbol
> >>__imp_?name@
> >>type_info@@QBEPBDXZ
> >>planarDirectedEdge.obj : error LNK2001: unresolved external symbol
> >>__imp_?name at t
> >>ype_info@@QBEPBDXZ
> >>Geometry.obj : error LNK2019: unresolved external symbol
> >>__imp_?name at type_info@@
> >>QBEPBDXZ referenced in function "private: virtual int __thiscall
> >>geos::Geometry:
> >>:getClassSortIndex(void)const " (?getClassSortIndex at Geometry@geos@@EBEHXZ)
> >>GeometryFactory.obj : error LNK2001: unresolved external symbol
> >>__imp_?name at type
> >>_info@@QBEPBDXZ
> >>GeometryGraph.obj : error LNK2001: unresolved external symbol
> >>nfo@@QBEPBDXZ
> >>OffsetCurveSetBuilder.obj : error LNK2001: unresolved external symbol
> >>__imp_?nam
> >>e at type_info@@QBEPBDXZ
> >>geos.dll : fatal error LNK1120: 1 unresolved externals
> >>NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
> >>8\VC\BIN\l
> >>ink.exe"' : return code '0x460'
> >>Stop.
> >>Is anybody able to help? Thanks in advance.
> >>Best regards,
> >>Bart
> >>OSGIS, Open Source GIS
> >>http://www.osgis.nl
> >>_______________________________________________
> >>geos-devel mailing list
> >>geos-devel at geos.refractions.net
> >>http://geos.refractions.net/mailman/listinfo/geos-devel
/"\ ASCII Ribbon Campaign
\ / Respect for low technology.
X Keep e-mail messages readable by any computer system.
/ \ Keep it ASCII.
