[geos-devel] building geos 2.2.1 using Visual Studio 8
Bart van den Eijnden (OSGIS)
bartvde at xs4all.nl
Mon Apr 3 12:39:10 EDT 2006
Hi list,
after applying this change the makefile from Mateusz does build a
geos.lib successfully using the 2.2 branch.
If I use all the 2.2 stuff from CVS (so CVS makefile), it builds a
geos.dll successfully as well.
Clean does not work though using the CVS makefile: too long. Stop.
Best regards,
Bart
Mateusz Ĺoskot wrote:
>Bart van den Eijnden (OSGIS) wrote:
>>io\markup\MarkupSTL.cpp(916) : error C2440: '=' : cannot convert from
>>'const cha
>>r *' to 'char *'
>> Conversion loses qualifiers
>Home made fix is:
>go to io\markup\MarkupSTL.cpp file, move to line 913:
>char* pFound;
>and change it to read:
>const char* pFound;
>Now it should work.
>Cheers
OSGIS, Open Source GIS
http://www.osgis.nl
