[geos-devel] building geos 2.2.1 using Visual Studio 8
Mateusz Łoskot mateusz at loskot.net
Mon Apr 3 13:50:58 EDT 2006
Charlie Savage wrote:
> I have a static library since my main goal is to build python and
> ruby extensions using SWIG - thus I need access to the C++ api.
I see. I use Static Library for simplicity when working with Unit Tests.
> Unfortunately, at least 2.2.2, doesn't expose classes via declspec.
> I once had a def file I manually generated (which you can use
> instead) but it was a bit of pain to keep it up to date.  I guess I
> could regenerate it for 2.2.2 which is stable.
Yes.
> When I get a chance I'll take a look and we can compare notes.
OK. Then I will put my comments and we can work out common vc++ project.
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
