[geos-devel] I'm lost with LineString
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Apr 3 20:50:07 EDT 2006
Mateusz,
AddPoint(linestring, point, [<position>])
I don't think you can easily remove a point. Dump(geometry) might allow
you to do it, but I'm not sure how it works.
I STRONGLY believe that there should be set of functions that allow
versatile construction, editing and deconstruction of geometries. I
think we have a good start at these, and it probably my limited
knowledge that prevents me from see how to do the others :)
-Steve
Mateusz Łoskot wrote:
> Hi,
> May be it's an extremely trivial problem or it's quite late and I should
> get to bad, but please help me :-)))
> The question is:
> how to add/remove point from existing instance of LineString class?
> I created LineString assigning to it object of type of
> CoordinateArraySequence with some points.
> Now, I'd like to add/remove points from this sequence assigned to
> linestring.
> How can I achive this simple functionality?
> I'm sure it's very simple, but I can not find it.
> Cheers
