[geos-devel] Using static values in Unit Tests
Mateusz Łoskot
mateusz at loskot.net
Tue Apr 4 12:29:01 EDT 2006
strk at refractions.net wrote:
>>> I'd go with a tolerance value, but rather then
>>> set it immediately I'll leave it for later, when
>>> we detect differences. I'd start with a tolerance of 0.
>> Ok, but I'm not sure I understand the idea correctly.
>> Do you mean to loop starting from tolerance = 0 and check if values are
>> equal, if not, tolerance is increased e.g. 0 + 0.001 and results are
>> compared again. Loop ends when results comparison = true.
>> Is this the idea?
> The idea is just to use a "global" tolerance value, to try
> at keeping it as small as possible. An automated loop could
> help finding out the minimum tolerance, but I'm not sure
> the complexity makes it worth.
I understand.
OK, I'll do some tests after I release UT.
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
