[geos-devel] [ANN] Bug #86 - Possible memory leaks caused by LineString constructor
Mateusz Łoskot mateusz at loskot.net
Wed Apr 5 20:47:49 EDT 2006
strk at refractions.net wrote:
> On Tue, Apr 04, 2006 at 07:27:14PM +0200, Mateusz Å?oskot wrote:
>> Hi,
>> I've just reported new bug, quite serious because it potentially causes
>> memory leaks when incomplete linesting is created.
>> So, I (re)report it here because it may need some discussion.
>> Here is the story:
>> http://postgis.refractions.net/bugs/bug.php?op=show&bugid=86&pos=3
> I think there are more then one such cases.
> The rationale for avoiding deletion is that caller might
> want to add an additional point and try construction again.
> Anyway, it's probably cleaner to always take full ownership
> of the passed argument and destroy it when unable to
> construct. So I'd proceed with your suggested solution.
I reopened this bug. As explained in the bug description, the problem is
not solved using this small fix. So, it applies to Bug #86  and Bug #89.
See the thread titled as "Exception-safety".
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
