[geos-devel] 2.2.2
strk at refractions.net
Tue Apr 11 12:49:36 EDT 2006
On Tue, Apr 11, 2006 at 10:19:01AM -0600, Charlie Savage wrote:
> Okay, I took the path of least resistance. Added errorEnum and changed
> ERROR to eError. That works. Let me know if I should change the rest,
> and then I'll provide a patch.
You should search all of GEOS .cpp and .h files for occurrences of
the label 'ERROR' and update them to eError.
Keep your finger crossed in doing so.
Note that existing client source code might fail to build
against 2.2.2 due to this change, while already compiled
code should keep working. Acceptable for a micro upgrade ?
--strk;
