[geos-devel] Actual CVS version of geos does not build
Silke Reimer Silke.Reimer at intevation.de
Wed Apr 12 06:43:37 EDT 2006
Hallo!
I just tried to build the actual geos CVS version on a 64-bit architecture
but I don't get it working:
# tar xjf geos-cvs.tar.bz2
# cd geos-3.0.0cvs/
# ./configure
# make
leads to
Making all in util
make[3]: Entering directory `/home/silke/geos-3.0.0cvs/source/geom/util'
if /bin/sh ../../../libtool --mode=compile --tag=CXX g++ -DHAVE_CONFIG_H -I. -I. -I../../../source/headers -I../../../source/headers/geos -I../../../source/headers     -g -O2 -DGEOS_INLINE -MT GeometryEditor.lo -MD -MP -MF ".deps/GeometryEditor.Tpo" -c -o GeometryEditor.lo GeometryEditor.cpp; \
then mv -f ".deps/GeometryEditor.Tpo" ".deps/GeometryEditor.Plo"; else rm -f ".deps/GeometryEditor.Tpo"; exit 1; fi
mkdir .libs
 g++ -DHAVE_CONFIG_H -I. -I. -I../../../source/headers -I../../../source/headers/geos -I../../../source/headers -g -O2 -DGEOS_INLINE -MT GeometryEditor.lo -MD -MP -MF .deps/GeometryEditor.Tpo -c GeometryEditor.cpp  -fPIC -DPIC -o .libs/GeometryEditor.o
In file included from ../../../source/headers/geos/geom/Geometry.h:649,
                 from ../../../source/headers/geos/geom/GeometryFactory.h:20,
                 from GeometryEditor.cpp:23:
../../../source/headers/geos/geom/Geometry.inl: In member function `const
   geos::geom::PrecisionModel* geos::geom::Geometry::getPrecisionModel() const
../../../source/headers/geos/geom/Geometry.inl:28: error: `getPrecisionModel'
   undeclared (first use this function)
../../../source/headers/geos/geom/Geometry.inl:28: error: (Each undeclared
   identifier is reported only once for each function it appears in.)
make[3]: *** [GeometryEditor.lo] Fehler 1
make[3]: Leaving directory `/home/silke/geos-3.0.0cvs/source/geom/util'
make[2]: *** [all-recursive] Fehler 1
make[2]: Leaving directory `/home/silke/geos-3.0.0cvs/source/geom'
make[1]: *** [all-recursive] Fehler 1
make[1]: Leaving directory `/home/silke/geos-3.0.0cvs/source'
make: *** [all-recursive] Fehler 1
Do you have any idea what's going wrong?
Please let me know if you need additional information.
Many greetings,
    Silke
Silke Reimer   : www.intevation.de/~silke | GISpatcher: www.gispatcher.de
Intevation GmbH: www.intevation.de        | Thuban    : thuban.intevation.org
Georgstr.4     : 49074 Osnabrück          | FreeGIS   : www.freegis.org
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060412/cda7e19c/attachment.bin
