[geos-devel] Using std::vector<bool> container
Mateusz Łoskot
mateusz at loskot.net
Sat Apr 22 15:53:09 EDT 2006
Today, I noticed GEOS uses containers with elements of type of bool:
std::vector<bool>.
I reported those cases as a bug on the GEOS Bug Tracker with quite
detailed explanation, also giving references for further reading:
http://postgis.refractions.net/bugs/bug.php?op=show&bugid=101&pos=11
Simply, despite that using vector of bools is a bad idea from technical
point of view, it also does not make any sense.
What is following code suppose to do?
vector<bool> v;
bool* pv = &v[0];
Does it mean we retrieve address of single bit?
So, this code is compilable but only because of std::vector<bool> is e
pseudo-container, specialized by STL (C++ Language Standard, Chapter
23.2.5).
Complete explanation of this issue is available in Scott Meyers' book
(see report #101).
I think it's quite important to write about it here, just to warn
developers before using std::vector<bool> in future.
I refer interested developers to documents presented in bug report #101.
Instead of using std::vector<bool>, it's safe and recommended to use
deque<bool> or bitset. bitset is not a part of STL but is part of C++
Standard Library (CSL), so it's not an external dependency.
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
