[geos-devel] geos on SLES9 64-bit
strk at refractions.net strk at refractions.net
Wed Apr 26 06:28:13 EDT 2006
Applied a slightly modified version. Thanks.
--strk;
On Tue, Apr 25, 2006 at 06:24:50PM +0200, Silke Reimer wrote:
> Within geos-config the libdir is been defined as $prefix/lib which obviously is
> wrong when working the SLES9 64-bit system. The problem can be solved rather
> easily by means of the following patch. It would be nice if you could apply it
> to the current geos CVS version.
