[geos-devel] RE: TaggedLineSegment
strk at refractions.net
Fri Apr 28 07:30:42 EDT 2006
On Wed, Apr 19, 2006 at 10:53:53AM -0700, Martin Davis wrote:
> I probably did this for simplicity of programming. I would think you
> can replace the subclass relationship with a uses relationship.
This won't remove the overhead associated with copying coordinates.
I'll leave it as it is for now, but this is a place that really
calls for shared_ptr<> usage...
Using pointers would be ok too, but I'm kind of scared of keeping
pointers to Coordinates returned from CoordinateSequence as
references, it's hard to ensure memory integrity that way
(adding a point to the source CoordinateSequence could trigger
a complete reallocation of the underlying vector)
--strk;
> > -----Original Message-----
> > From: strk [mailto:strk at keybit.net]
> > Sent: April 12, 2006 9:19 AM
> > To: Martin Davis
> > Cc: geos-devel at geos.refractions.net
> > Subject: TaggedLineSegment
> > Martin, I'm porting the jts.simplify package
> > to GEOS and I have a design question.
> > Is it a problem if we avoid to have TaggedLineSegment
> > derive from LineSegment ? This is probably not a problem
> > with JTS, but in GEOS LineSegment is composed by 2 real
> > Coordinates rather then pointers and we probably don't need
> > the overhead associated with this. Moreover this would
> > require LineSegment to become a polymorphic class whereas
> > currently it is not (in head at least, this would be the
> > first derivate of it).
