[geos-devel] SVN - Line Feeds
Charlie Savage cfis at savagexi.com
Thu Aug 3 17:29:02 EDT 2006
Okay, I've tracked down an issue caused by the move to SVN.
By default, SVN does not convert line feeds based on platform, unlike
CVS.  However, you can override this either by local setting on your
machine or by adding a property to each file.  For more information see:
http://svnbook.red-bean.com/en/1.0/ch07s02.html#svn-ch-7-sect-2.3.5
It looks like in the automated move to SVN, every file was tagged with
svn:eol-style native.
So, on Windows, you get CR/LF while on *Nix its just Line Feed.  Thus
configure.in gets CR/LF which breaks autoconf on line 297 when compiling
under MingW.
It seems to me the best solution is to remove this property on every
file so code checks out the same on every system.  Alternatively, I can
play with .configure.in to see if I can get it to work on both platforms
(since everything else seems to at least compile).
What should I do?
Charlie
strk at refractions.net wrote:
> On Thu, Aug 03, 2006 at 12:11:40PM -0600, Charlie Savage wrote:
>> For GEOS 3 it would be really good to support mingw.  I have not been
>> able to compile the geos 3 head branch using migw for a long time - I
>> get a series of linker errors that I posted to the last about a month
>> ago.  Any help fixing them would be appreciated.
>> Anyway, just tried again after the move to SVN.  And this time I can't
>> get past autogen didn't work.
>> $ ./autogen.sh
>> Running autoheader
>> ' is already registered with AC_CONFIG_FILES.
>> autoconf/status.m4:848: AC_CONFIG_FILES is expanded from...
>> configure.in:297:
> Could you try the version in CVS ? (just in case it's CR/NL issue).
> --strk;
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060803/9a09b0fd/smime.bin
