[geos-devel] Re: GEOS / SRID / WKB
strk at refractions.net
Wed Feb 1 20:57:33 EST 2006
Charlie, we're playing dirty here, even for Z values.
One thing is accepting "extensions", another thing is spitting them out.
Z,M and SRID flags are postgis-specific.
The next update on OGC dox will define a different way to express
Z and M for example, and won't say anything about SRID.
The most correct way to support multiple different specs
would be to provide a method to specify which one to use.
For example:
WKBWriter writer;
writer.setFormat(DIALECT);
writer.write(geom);
Same would apply to WKBReader and to WKT reader/writer.
--strk;
On Wed, Feb 01, 2006 at 06:50:07PM -0700, Charlie Savage wrote:
> I'd like to be able to read/write SRID information from GEOS using the
> WKB Reader/Writer. Currently the WKBReader reads the SRID value in an
> extended WKB format, but then tosses it away. Attached is a patch that
> saves the SRID value by calling setSRID on the newly created geometry.
> It would also be nice if WKBWriter could output SRID values. Looking
> through the code, it would be easy enough to write this information
> out. However, if a geometry has an SRID, the output WKB value would be
> one byte longer plus have an SRID flag in the geomtype byte. So this
> would break existing code that reads wkb values if a geometry has an
> SRID. I'm not sure if this is an issue or not, since I see the SRID
> field on a geometry is not documented. Is this a frequently used
> feature? An alternative of course would be having a separate method,
> maybe called writeExtended or some such thing.
> Thanks,
> Charlie
> Index: source/io/WKBReader.cpp
> RCS file: /home/cvs/postgis/geos/source/io/WKBReader.cpp,v
> retrieving revision 1.15
> diff -u -r1.15 WKBReader.cpp
> --- source/io/WKBReader.cpp 20 Jan 2006 00:59:55 -0000 1.15
> +++ source/io/WKBReader.cpp 2 Feb 2006 01:44:16 -0000
> @@ -230,31 +230,43 @@
> cout<<"WKB hasSRID: "<<hasZ<<endl;
> #endif
> - if (hasSRID) dis.readInt(); // skip SRID
> + int srid = -1;
> + if (hasSRID) srid = dis.readInt(); // read SRID
> // allocate space for ordValues
> if ( ordValues.size() < inputDimension )
> ordValues.resize(inputDimension);
> + Geometry * result;
> switch (geometryType) {
> case WKBConstants::wkbPoint :
> - return readPoint();
> + result = readPoint();
> + break;
> case WKBConstants::wkbLineString :
> - return readLineString();
> + result = readLineString();
> + break;
> case WKBConstants::wkbPolygon :
> - return readPolygon();
> + result = readPolygon();
> + break;
> case WKBConstants::wkbMultiPoint :
> - return readMultiPoint();
> + result = readMultiPoint();
> + break;
> case WKBConstants::wkbMultiLineString :
> - return readMultiLineString();
> + result = readMultiLineString();
> + break;
> case WKBConstants::wkbMultiPolygon :
> - return readMultiPolygon();
> + result = readMultiPolygon();
> + break;
> case WKBConstants::wkbGeometryCollection :
> - return readGeometryCollection();
> + result = readGeometryCollection();
> + break;
> + default:
> + throw new ParseException("Unknown WKB type " + geometryType);
> - throw new ParseException("Unknown WKB type " + geometryType);
> + result->setSRID(srid);
> + return result;
> Point *
| Fight against software patents in EU! |
| www.ffii.org www.nosoftwarepatents.org |
