[geos-devel] Re: GEOS / SRID / WKB
Charlie Savage cfis at interserv.com
Thu Feb 2 19:07:01 EST 2006
Any chance get/set SRID could be "undeprecated?"
The reason is that it is much harder to use userdata. With get/set SRID
all you have to do is set an integer. With user data you have deal with
allocating/deallocating memory instead of setting a simple integer.
That's ok, but it becomes harder if you want to clone geometries.  If
you do that, then the clone methods (which end up eventually in the copy
constructor of Geometry) set the new object's user data to null, which
is reasonable since its a pointer.  But that makes it hard to make use
of the user data to store SRID values - since you have to first clone
the object then manually copy over the user data.
I realize that SRID values don't play a role in the traditional use
cases for GEOS.  I gather I'm using it in a bit of a non-traditional way
- as a client-side library for being able to read in data queried from
PostGIS, then use Ruby to work with that data.  So the SRID values for
my case are quite important.  I think that as the use of GEOS increases,
this type of usage could become more common.
The only things I really need for this are:
1.  Keeping get/set SRID around
2.  Saving srid values read from the WKB format (see patch from yesterday).
3.  A change in the Geometry copy constructor - right now when you clone
an object the new object gets its SRID value from the geometry factory
and not from the cloned geometry.  That seems incorrect to me - I'd
expect if you'd clone an object you'd get a true copy of it (I can
provide a patch for this, its a one line change).
4.  It would be nice to be able to write out the SRID values in EWKT or
EWKB, but that's not really critical.
So one vote to keep get/set SRID as official parts of the api....
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060202/432f6a8b/smime.bin
