[geos-devel] WKBReader Bug Fixed
Wed Feb 8 20:56:42 EST 2006
On 2/8/06, strk at refractions.net <strk at refractions.net> wrote:
> Did you notice where the exception handler was at all ?
> --strk;
The WKBReader::readLineString() is calling dis.readInt()
which apparently throws an exception.  I can't seem to
debug into it.
It is trapped in the GEOSException case within
GEOSGeomFromWKB_buf().   The ERROR_MESSAGE
triggers a seg fault.
I didn't seem to have debug info on the "ge"
exception, and so couldn't inspect it to see what
was going.
I wish I could provide a more authoritative report
on the exception problem but there is just too much
opaque stuff when I try to step through in gdb.
Best regards,
