[geos-devel] CAPI and libtool (question for BSD users)
strk at refractions.net
Thu Feb 9 11:10:27 EST 2006
The CAPI has a new function GEOSArea().
Libtool manual says that this should trigger
an INTERFACE_CURRENT increment, so from
CURRENT=1
AGE=0
REVISION=1
we should go to
CURRENT=2
AGE=1 // support all previous interfaces
REVISION=0
I know this will bring to libgeos_c.so.1.1.0
under GNU/Linux, but IIRC on BSD systems this
resulted in 2.0.0 instead, if not worst.
Is there any BSD user willing to test this ?
Basically we need to check:
1) what would the resulting library
SONAME be in BSD
2) if 2.0.0 wheter ABI compatibility
is really broke or not (could
be libtool is right)
Volunteers ?
--strk;
