[geos-devel] SegmentString modeling
strk at refractions.net strk at refractions.net
Thu Feb 16 12:06:31 EST 2006
Need some help from C++ gurus.
One of the new JTS classes expects to modify
the Coordinates associated with a SegmentString.
So far the SegmentString kept a const-pointe
to an externally provided CoordinateSequence.
This means you can't modify a CoordinateSequence
getting it's pointer from the SegmentString,
even if the SegmentString itself is non-const
(it's not the owner of the CoordinateSequence).
Changing the interface to allow SegmentString
to keep non-const pointers to CoordinateSequence
instead, will break all promises of constness
on which existing code relies.
What I'd like to model is a SegmentString
that will either store a const or a non-const
pointer to CoordinateSequence depending on
construction. Is it possible at all w/out
making it a templated class ?
--strk;
