[geos-devel] SegmentString modeling
strk at refractions.net
Thu Feb 16 12:54:40 EST 2006
Are you suggesting SegmentString should take ownership
of the passed CoordinateSequence ?
This is not how it currently works. Not that I like current
behaviour, but I'm trying to understand your suggestion.
In the examples you show B takes ownership of B*, things
get simpler in that case. But when B does not own C, changing
C isn't the same as changing B.
--strk;
On Thu, Feb 16, 2006 at 06:44:12PM +0100, Mateusz Å?oskot wrote:
> strk at refractions.net wrote:
> >Need some help from C++ gurus.
> >One of the new JTS classes expects to modify
> >the Coordinates associated with a SegmentString.
> >So far the SegmentString kept a const-pointe
> >to an externally provided CoordinateSequence.
> >This means you can't modify a CoordinateSequence
> >getting it's pointer from the SegmentString,
> >even if the SegmentString itself is non-const
> >(it's not the owner of the CoordinateSequence).
> I've taken a look at GEOS sources and that's clear for me.
> >Changing the interface to allow SegmentString
> >to keep non-const pointers to CoordinateSequence
> >instead, will break all promises of constness
> >on which existing code relies.
> IMHO it does not make sense saying storing data member by non-const
> pointer "will break all promises of constness".
> You can store data member as private and non-const and you still can
> provide 100% of const correctness by encapsulation this data member.
> IMO current design of collaboration of SegmentString and
> CoordinateString is wrong. SegmentString should store non-const pointer
> to CoordinateString *and* provide appropriate API which keep things
> correct from const point of view.
> Keeping CoordinateSequence by const pointer is really hazardous because
> it will likely be changed/edited in some contexts.
> Check STL sources and you will see that e.g. std::vector::bedin() and
> std::vector::end() are provided in two versions: const and non-const, so
> you can retrive vector elements by as read-only - by const reference or
> read-write by non-const reference depending on current context.
> Check this piece of code:
> #include <iostream>
> using namespace std;
> struct C
> int mx;
> int my;
> C() : mx(0), my(0) {}
> class B
> C* c; // Store C by non-const pointer
> public:
> B(C* pc) : c(pc) {}
> ~B() { delete c; }
> // Const correctness provided by properly designed API
> C* get() { return c; }
> const C* get() const { return c; }
> int main()
> // Create objects
> C* pc = new C();
> B b(pc);
> // Retrieve B::c by non-const pointer to edit B::c data members
> C* c1 = b.get(); // Here no constness is required
> cout << "0: " << c1->mx << " " << c1->my << endl;
> c1->mx = 9;
> c1->my = 10;
> // Now, retrieve B::c by *const* pointer to only *read* B::c member
> const C* c2 = b.get(); // Here const correctness is provided
> cout << "1: " << c2->mx << " " << c2->my << endl;
> // uncomment and you'll get compilation error
> //c2->mx = 10; // c2 is read-only !!!
> So, B::get() interface provide proper const correctness if any context
> will require it.
> Certainly, in other classes, non-editable by design, you can provide
> read-only interface:
> class ReadOnlyB
> public:
> B(C* pc) : c(pc) {}
> ~B() { delete c; }
> >What I'd like to model is a SegmentString
> >that will either store a const or a non-const
> >pointer to CoordinateSequence depending on
> >construction. Is it possible at all w/out
> >making it a templated class ?
> I don't like it. Well working const correctness and encapsulation can be
> achived by properly modeled class interface but not by class internals.
> Class internals should be separated from outside world by class
> interface and not its (internals) implementation, that's why you can
> hide data in class and provide proper interface. If you will need
> another behaviour e.g. read-write instead of read-only then you can add
> functions to class interface and if you need read-only behaviour of
> read-write class then you can wrap it behind read-only interface.
> Cheers
> Mateusz Åoskot
> http://mateusz.loskot.net
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
State-collected Geographic Data is public property
-*- sign the petition -*-
http://petition.publicgeodata.org
