[geos-devel] Building latest CVS HEAD with MSVC++ 8.0
Mateusz Łoskot
mateusz at loskot.net
Thu Feb 23 05:20:04 EST 2006
Frank Warmerdam wrote:
> Charlie Savage wrote:
>> I was just offering to donate the Visual Studio C++ Solution files
>> (i.e., the VC++ project files) that I have to GEOS.
>> That is a separate thing from fixing the round function, which stops
>> VC++ from compiling GEOS whether you use Visual Studio, the Visual
>> Studio command line or nmake.
>> However, I gather the VC++ community doesn't use GEOS much though,
>> since there aren't any Visual Studio files or build scripts that GEOS
>> provides that work with VC++.
> Charlie,
> Note, there are NMAKE files which I have maintained. There used to be a
> project file, but no one maintained it.
Yes, there are makefiles for NMAKE.
2 days ago I started to update makefile.vc, it's not finished because I
stucked with missing round function. So, if it will be fixed (or
removed) I'll continue to work on it.
BTW, I think round may be safely removed.
Charlie,
Thanks for your offer about project files but I have created them myself
for VC++ 8.0. I think some projects could be available on CVS but it's
hard to keep them up to date while serious changes are made to the repo
everyday (remove/add files).
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
