[geos-devel] geos-2.2.0 / FreeBSD 4
Benjamin Thelen
bt at ccgis.de
Mon Jan 9 08:27:28 EST 2006
Well, I don't have 2.96, but I have 3.4.6, what doesn't do a better job,
I'm afraid:
Making all in capi
gmake[2]: Entering directory
`/data/ports/graphics/geos/work/geos-2.2.1/source/capi'
if /bin/sh /usr/local/bin/libtool15 --mode=compile --tag=CXX g++34
-DHAVE_CONFIG_H -I. -I. -I../../source/headers
-I../../source/headers/geos -DGEOS_CAPI_VERSION='"2.2.1-CAPI-1.0.1"'
-O -pipe -march=pentiumpro -MT libgeos_c_la-geos_c.lo -MD -MP -MF
".deps/libgeos_c_la-geos_c.Tpo" -c -o libgeos_c_la-geos_c.lo `test -f
'geos_c.cpp' || echo './'`geos_c.cpp; \
then mv -f ".deps/libgeos_c_la-geos_c.Tpo"
".deps/libgeos_c_la-geos_c.Plo"; else rm -f
".deps/libgeos_c_la-geos_c.Tpo"; exit 1; fi
mkdir .libs
g++34 -DHAVE_CONFIG_H -I. -I. -I../../source/headers
-I../../source/headers/geos -DGEOS_CAPI_VERSION=\"2.2.1-CAPI-1.0.1\" -O
.deps/libgeos_c_la-geos_c.Tpo -c geos_c.cpp -fPIC -DPIC -o
.libs/libgeos_c_la-geos_c.o
.deps/libgeos_c_la-geos_c.Tpo -c geos_c.cpp -o libgeos_c_la-geos_c.o
>/dev/null 2>&1
/bin/sh /usr/local/bin/libtool15 --mode=link --tag=CXX g++34 -O -pipe
-march=pentiumpro -o libgeos_c.la -rpath /usr/local/lib -version-info
1:1:0 -no-undefined libgeos_c_la-geos_c.lo ../../source/geom/libgeos.la
c++ -shared -nostdlib /usr/lib/crti.o /usr/lib/crtbeginS.o
.libs/libgeos_c_la-geos_c.o -Wl,--rpath
-Wl,/data/ports/graphics/geos/work/geos-2.2.1/source/geom/.libs
-Wl,--rpath -Wl,/usr/local/lib ../../source/geom/.libs/libgeos.so
-L/usr/lib -lstdc++ -lm -lgcc /usr/lib/crtendS.o /usr/lib/crtn.o
-march=pentiumpro -Wl,-soname -Wl,libgeos_c.so.1 -o .libs/libgeos_c.so.1
(cd .libs && rm -f libgeos_c.so && ln -s libgeos_c.so.1 libgeos_c.so)
ar cru .libs/libgeos_c.a libgeos_c_la-geos_c.o
ranlib .libs/libgeos_c.a
creating libgeos_c.la
(cd .libs && rm -f libgeos_c.la && ln -s ../libgeos_c.la libgeos_c.la)
if gcc34 -DHAVE_CONFIG_H -I. -I. -I../../source/headers
-I../../source/headers/geos -O -pipe -march=pentiumpro -MT
geostest.o -MD -MP -MF ".deps/geostest.Tpo" -c -o geostest.o geostest.c; \
then mv -f ".deps/geostest.Tpo" ".deps/geostest.Po"; else rm -f
".deps/geostest.Tpo"; exit 1; fi
/bin/sh /usr/local/bin/libtool15 --mode=link --tag=CC gcc34 -O -pipe
-march=pentiumpro -o geostest geostest.o libgeos_c.la
gcc34 -O -pipe -march=pentiumpro -o .libs/geostest geostest.o
./.libs/libgeos_c.so
/data/ports/graphics/geos/work/geos-2.2.1/source/geom/.libs/libgeos.so
../../source/geom/.libs/libgeos.so -Wl,--rpath -Wl,/usr/local/lib
/data/ports/graphics/geos/work/geos-2.2.1/source/geom/.libs/libgeos.so:
undefined reference to `std::basic_ios<char, std::char_traits<char>
>::init(std::basic_streambuf<char, std::char_traits<char> >*)'
undefined reference to `std::basic_ostream<char, std::char_traits<char>
>& std::operator<< <std::char_traits<char> >(std::basic_ostream<char,
std::char_traits<char> >&, char const*)'
undefined reference to `__cxa_rethrow'
>& std::operator<< <char, std::char_traits<char>
>(std::basic_ostream<char, std::char_traits<char> >&, std::_Setw)'
undefined reference to `std::basic_string<char, std::char_traits<char>,
std::allocator<char> >::basic_string(unsigned int, char,
std::allocator<char> const&)'
std::allocator<char> >::operator+=(char)'
undefined reference to `__gnu_cxx::__exchange_and_add(int volatile*, int)'
std::allocator<char> >::operator=(char const*)'
undefined reference to `std::_Rb_tree_decrement(std::_Rb_tree_node_base*)'
undefined reference to `vtable for std::basic_ostringstream<char,
std::char_traits<char>, std::allocator<char> >'
std::allocator<char> >::compare(char const*) const'
./.libs/libgeos_c.so: undefined reference to `std::basic_string<char,
>::basic_string(std::basic_string<char, std::char_traits<char>,
std::allocator<char> > const&)'
`std::basic_ostringstream<char, std::char_traits<char>,
std::allocator<char> >::str() const'
undefined reference to `std::cerr'
std::char_traits<char> >&, char)'
undefined reference to `typeinfo for void*'
undefined reference to `std::allocator<char>::~allocator()'
>::operator=(std::basic_string<char, std::char_traits<char>,
`std::allocator<char>::allocator()'
undefined reference to `VTT for std::basic_ostringstream<char,
std::allocator<char> >::append(char const*)'
std::allocator<char> >::assign(std::basic_string<char,
std::char_traits<char>, std::allocator<char> > const&)'
./.libs/libgeos_c.so: undefined reference to `vtable for
__cxxabiv1::__pointer_type_info'
undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
std::char_traits<char>, std::allocator<char> >::~basic_string()'
>::operator<<(std::basic_ostream<char, std::char_traits<char> >&
(*)(std::basic_ostream<char, std::char_traits<char> >&))'
>::~basic_ios()'
./.libs/libgeos_c.so: undefined reference to `operator delete(void*)'
undefined reference to `std::_Rb_tree_increment(std::_Rb_tree_node_base
const*)'
>::eof() const'
./.libs/libgeos_c.so: undefined reference to `__cxa_end_catch'
`std::allocator<char>::allocator(std::allocator<char> const&)'
undefined reference to `std::basic_stringbuf<char,
>::basic_stringbuf(std::_Ios_Openmode)'
./.libs/libgeos_c.so: undefined reference to `__gxx_personality_v0'
./.libs/libgeos_c.so: undefined reference to `typeinfo for std::exception'
std::allocator<char> >::reserve(unsigned int)'
>::operator void*() const'
std::allocator<char> >::_Rep::_S_empty_rep_storage'
undefined reference to `__cxa_pure_virtual'
>::operator<<(int)'
std::allocator<char> >::operator[](unsigned int)'
undefined reference to `std::ios_base::ios_base()'
>::operator<<(unsigned int)'
>::basic_ostream()'
>::widen(char) const'
undefined reference to `std::locale::~locale()'
./.libs/libgeos_c.so: undefined reference to `std::ios_base::Init::Init()'
undefined reference to `std::basic_istream<char, std::char_traits<char>
>::read(char*, int)'
undefined reference to `vtable for __cxxabiv1::__class_type_info'
undefined reference to `__cxa_throw'
std::allocator<char> >::find_first_not_of(char const*, unsigned int) const'
`std::basic_istringstream<char, std::char_traits<char>,
std::allocator<char> >::~basic_istringstream()'
undefined reference to `std::_Rb_tree_insert_and_rebalance(bool,
std::_Rb_tree_node_base*, std::_Rb_tree_node_base*,
std::_Rb_tree_node_base&)'
>::~basic_ostream()'
std::allocator<char> >::append(std::basic_string<char,
./.libs/libgeos_c.so: undefined reference to `std::basic_istream<char,
std::char_traits<char> >::seekg(long long, std::_Ios_Seekdir)'
std::char_traits<char>, std::allocator<char> >::basic_string(char
const*, std::allocator<char> const&)'
`std::_Rb_tree_rebalance_for_erase(std::_Rb_tree_node_base*,
>::tellg()'
std::allocator<char> >::_M_leak_hard()'
undefined reference to `vtable for __cxxabiv1::__vmi_class_type_info'
std::allocator<char> >::substr(unsigned int, unsigned int) const'
./.libs/libgeos_c.so: undefined reference to `std::ios_base::Init::~Init()'
undefined reference to `vtable for std::basic_stringbuf<char,
undefined reference to `vtable for std::basic_streambuf<char,
std::char_traits<char> >'
const*, unsigned int, std::allocator<char> const&)'
./.libs/libgeos_c.so: undefined reference to `__cxa_begin_catch'
undefined reference to `__cxa_allocate_exception'
undefined reference to `vtable for std::basic_ios<char,
>& std::endl<char, std::char_traits<char> >(std::basic_ostream<char,
std::char_traits<char> >&)'
std::allocator<char> >::~basic_ostringstream()'
>::write(char const*, int)'
undefined reference to `std::_Rb_tree_increment(std::_Rb_tree_node_base*)'
undefined reference to `std::cout'
./.libs/libgeos_c.so: undefined reference to `operator new(unsigned int)'
std::allocator<char> >::operator+=(std::basic_string<char,
std::allocator<char> >::find_first_of(char const*, unsigned int) const'
std::char_traits<char>, std::allocator<char> >::c_str() const'
>::clear(std::_Ios_Iostate)'
>::operator<<(double)'
std::allocator<char> >::str(std::basic_string<char,
std::allocator<char> >::basic_istringstream(std::_Ios_Openmode)'
std::allocator<char> >::operator+=(char const*)'
std::allocator<char> >::basic_ostringstream(std::_Ios_Openmode)'
std::char_traits<char>, std::allocator<char> >::length() const'
undefined reference to `__cxa_bad_typeid'
>& std::operator<< <char, std::char_traits<char>, std::allocator<char>
std::basic_string<char, std::char_traits<char>, std::allocator<char> >
const&)'
std::allocator<char> >::_Rep::_M_destroy(std::allocator<char> const&)'
>::seekg(std::fpos<__mbstate_t>)'
std::allocator<char> >::_Rep::_M_refdata()'
std::char_traits<char>, std::allocator<char> >::basic_string()'
std::allocator<char> >::append(char const*, unsigned int)'
collect2: ld returned 1 exit status
gmake[2]: *** [geostest] Error 1
gmake[2]: Leaving directory
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory
`/data/ports/graphics/geos/work/geos-2.2.1/source'
gmake: *** [all-recursive] Error 1
*** Error code 2
Stop in /data/ports/graphics/geos.
Ben
strk at refractions.net schrieb:
>>From the INSTALL file in GEOS toplevel dir:
> Compatibility notes
> GCC 2.95.2 seems to lack the 'sstream' header file required
> to build GEOS. GCC 2.96 is known to work.
> --strk;
> On Mon, Jan 09, 2006 at 12:05:48PM +0100, Benjamin Thelen wrote:
>>Hello,
>>Ups, sorry, my fault. I've been so busy with this, that I mistakenly
>>assumed that you of course know what I'm talking about :-). Sorry.
>>Building geos-2.2.1 fails on FreeBSD 4.11 (gcc-2.95) with this error:
>> g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers
>>-I../../source/headers/geos -I../../source/headers -DGEOS_VERSION=2.2.1
>>-g -O2 -c ../io/WKBReader.cpp -Wp,-MD,.deps/WKBReader.TPlo -fPIC -DPIC
>>-o .libs/WKBReader.o
>>../io/WKBReader.cpp: In function `static class ostream &
>>geos::WKBReader::printHEX(istream &, ostream &)':
>>../io/WKBReader.cpp:27: syntax error before `::'
>>../io/WKBReader.cpp:46: `fl' undeclared (first use this function)
>>../io/WKBReader.cpp:46: (Each undeclared identifier is reported only once
>>../io/WKBReader.cpp:46: for each function it appears in.)
>>gmake[2]: *** [WKBReader.lo] Error 1
>>gmake[2]: Leaving directory `/data/src/geos-2.2.1/source/geom'
>>gmake[1]: Leaving directory `/data/src/geos-2.2.1/source'
>>If you need to have more information, please let me know!
>>Any idea?
>>Kind Regards,
>>Ben
>>>If you are more specific on what's wrong we *might* help.
>>>--strk;
>>>On Fri, Dec 23, 2005 at 08:52:55AM +0100, Benjamin Thelen wrote:
>>>>Hello list,
>>>>I've just subscribed to the geos-devel list in order to ask what it's
>>>>about geos > 2.1.4 (which succesfully builds on FreeBSD4) on FreeBSD4
>>>>and saw that the responsible FreeBSD portmaintainer has already been
>>>>asking there. But to be honest, I did't get the conclusion, whether you
>>>>or he is working on a solution or whether there already is a solution or
>>>>whether there is just no.
>>>>I've just tried to build 2.2.0, 2.2.1 using gcc-3.4, but without success.
>>>>What's the status, will there be a solution or a workaround? This would
>>>>really be great! I'd really appreciate any information.
>>>>Thanks,
>>>>Ben
>>>_______________________________________________
>>>geos-devel mailing list
>>>geos-devel at geos.refractions.net
>>>http://geos.refractions.net/mailman/listinfo/geos-devel
