[geos-devel] initGEOS/finishGEOS and multiple subsystems
    Stephen Lime
    sdlime at comcast.net
    Sun Jul  2 11:42:56 EDT 2006
Is there any issue with the error/warning functions that may be pointed
to? Can different
subsystems use separate functions at the same time?
Steve
On Jun 30, 2006, at 9:31 AM, Howard Butler wrote:
> Recently, Steve Lime reconfigured MapServer to use the GEOS C API
> instead of the C++ one.  Python Cartographic Library, which builds on
> MapServer and GEOS, among other things, *also* uses the GEOS C API.
> Each subsystem doesn't know when the other is calling
> initGEOS/finishGEOS, and on teardown, this is causing a segfault
> because the geomFactory has already been destroyed.
> After some discussion on #gdal with Frank, Norman, and Mateusz, we
> suggest that initGEOS/finishGEOS do some reference counting to ensure
> that geomFactory isn't prematurely destroyed.
> Does this seem reasonable?
> Howard
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
