[geos-devel] Linemerge operation broken in geos-cvs.tar.bz2
Albert Rovira Brugués
arovira at ngeografics.com
Thu Jul 6 04:39:55 EDT 2006
Now works, thank you !!
Finally I made some tests with the functions of this library and works
very well.
Congratulations all development team, It's a good work !!
Thanks,
Albert.
En/na strk at refractions.net ha escrit:
>On Wed, Jul 05, 2006 at 04:24:03PM +0200, Albert Rovira Brugués wrote:
>>Hi,
>>I tryed compile the current distribution of geos-cvs.tar.bz2 but I get
>>some errors because there are some missing headers files :
>>EdgeString.cpp:
>> 'geos/operation/linemerge/LineMergeEdge.h': No such file or directory
>I confirm the bug.
>If you can test the next generated snapshot (in an hour from now)
>it should be fixed.
>Thanks for pointing out!
>--strk;
>_______________________________________________
>geos-devel mailing list
>geos-devel at geos.refractions.net
>http://geos.refractions.net/mailman/listinfo/geos-devel
