[geos-devel] c api questions for SWIG
Charlie Savage cfis at savagexi.com
Mon Jul 10 17:13:28 EDT 2006
While I'm working through the SWIG bindings, I've come up with a few
questions/issues about the c api.
1.  GEOSGeomTypeId.  This is both a method name in the CAPI and the name
of an enum.  This causes problems in the SWIG bindings because I have
code that does this:
     GEOSGeomTypeIdgeomId = (GEOSGeomTypeId)GEOSGeomTypeId(geom);
     switch (geomId)
     case GEOS_POINT:
     case GEOS_LINESTRING:
     etc.
VC++ won't compile this code (haven't checked gcc).  However, it seems
like a bad idea to have the same identifier used for two different
things.  Can we change the name of the enum to something like GeomTypeID?
2.  Message handlers have this signature:
    typedef void (*GEOSMessageHandler)(const char *fmt, ...);
Are the ... parameters ever used (I didn't see any place where they
were).  If they are used, what are they?  If not, should they be removed?
3.  Init/Finish.  In SWIG I can automatically call initGEOS and install
the message handlers.  But I don't know of a way to call finishGEOS
automatically.  What happens if the SWIG bindings don't call it?
Thanks,
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060710/9801572d/smime.bin
