[geos-devel] c api feedback
Charlie Savage
cfis at savagexi.com
Wed Jul 12 17:36:42 EDT 2006
> 1. The methods GEOSCoordSeq_getSize and GEOSCoordSeq_getDimensions
> return their results by updating a pointer to a size_t parameter. Thus
> like this:
> GEOSCoordSeq_getSize(const GEOSCoordSeq s, size_t *size);
> In contrast, these methods just return the result:
> GEOSGeom_getDimensions returns value, not as a parameter
> GEOSGeom_getNumcoordinates
> GEOSGeom_getNumInteriorRings
> GEOSGeom_getNumGeometries
> Seems like an unneeded inconsistency.
A follow up to this. The methods like GEOSGeom_genNumcoordinates are
defined like this:
/* Return -1 on exception */
extern size_t GEOS_DLL GEOSGetNumCoordinates(const GEOSGeom g1);
However, size_t is defined as:
typedef unsigned int size_t
So returning -1 isn't such a good idea is it? You'd have to type cast
to an int first to check the result.
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060712/8480af2e/smime.bin
