[geos-devel] geometry validation and simplfiy problem
zhangjing
jingzhang at cbigroup.com
Fri Jul 14 22:43:10 EDT 2006
thanks Martin,
>Not currently, but it would be nice to have. I have done some work in
>this direction, but it's not really in a releasable state.
yes, really looking forward.
>When you "simplify" a polygon with a hole which crosses outside the
>outer shell, what happens to the part that is outside? Does it
>disappear, or become another polygon?
i believe it will become another polygon. i think all i want is to make the
LineRings into topology correct polygon(multipolygon).
>One thing you can do which should work almost all the time is to run
>buffer(0) on the invalid polygon. Buffer is very tolerant of bad
>topology, and will generally fix the polygon in the way I suspect you
>are looking for.
i will try buffer(0). will buffer(0) simplify a self-intersected polygon?
thanks.
