[geos-devel] Re: New python/ruby SWIG bindings checked in / Can't
build on Mac OSX
Robert J. Berger
rberger at ibd.com
Tue Jul 25 13:04:26 EDT 2006
Ok, what I needed to do was to modify autogen.sh in the top level
directory to use
glibtoolize instead of libtoolize.
If I had been a bit more aware when I first ran autogen.sh I would
have seen the error message:
./autogen.sh: line 16: libtoolize: command not found
Thanks for the help!
Rob
On Jul 25, 2006, at 5:57 AM, Howard Butler wrote:
> Robert,
> Can you try using /usr/bin/glibtool instead of osx's? The buildbot
> <http://geos.builds.hobu.net> currently configures with glibtool.
> I have had much trouble with osx's libtool (to the point of
> symlinking glibtool in its place even).
> Howard
> At 2:25 AM -0600 7/25/06, Charlie Savage wrote:
>> Content-Type: multipart/signed; protocol="application/x-pkcs7-
>> signature";
>> micalg=sha1; boundary="------------ms080105020904040701090001"
>>> Like should I be able to just run autgen.sh to build the proper
>>> configure files?
>> Yup, that should work:
>> ./autogen.sh
>> > Now I have to just learn how to use GEOS, POSTGIS, Ruby and
>> Google Earth
>>> KML without any background in GIS :-)
>> Good luck. Some ruby examples for GEOS are under swig/ruby/test,
>> and a python example is under swig/python/test.
>> Charlie
>> Content-Type: application/x-pkcs7-signature; name="smime.p7s"
>> Content-Disposition: attachment; filename="smime.p7s"
>> Content-Description: S/MIME Cryptographic Signature
>> Attachment converted: Macintosh HD:smime 186.p7s ( / )
>> (00445870)
>> geos-devel mailing list
>> geos-devel at geos.refractions.net
>> http://geos.refractions.net/mailman/listinfo/geos-devel
Robert J. Berger - Internet Bandwidth Development, LLC.
Voice: 408-882-4755 eFax: +1-408-490-2868
http://www.ibd.com
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20060725/112465f6/attachment.html
