[geos-devel] Re: [postgis-devel] Re: CVS to SVN move
Mateusz Loskot mateusz at loskot.net
Wed Jul 26 15:06:02 EDT 2006
Paul Ramsey wrote:
> The deed is done.
> http://svn.refractions.net/postgis
> http://svn.refractions.net/geos
I'd like to confirm:
- clean checkout - works
- autogen.sh/configure - works
- make - works
- make check - works
- make dist - does not work
Here is the error message I get when running 'make dist':
make[2]: Entering directory `/home/mloskot/dev/geos/_svn/geos/swig/python'
make[2]: *** No rule to make target `geos.py', needed by `distdir'.  Stop.
make[2]: Leaving directory `/home/mloskot/dev/geos/_svn/geos/swig/python'
make[1]: *** [distdir] Error 1
make[1]: Leaving directory `/home/mloskot/dev/geos/_svn/geos/swig'
make: *** [distdir] Error 1
Best regards
Mateusz Loskot
http://mateusz.loskot.net
