[geos-devel] Re: [postgis-devel] Re: CVS to SVN move
Paul Ramsey pramsey at refractions.net
Wed Jul 26 15:53:04 EDT 2006
The usual issues apply to putting generated files into the repository:
if different people with different swigs generate these files they will
potentially clobber each other in the repository and even generate
conflicts.
A checks out
B checks out
A generates and updates and commits
B generates and updates, conflict!
P
Charlie Savage wrote:
> Hmm...Looks like goes.py is not in SVN (probably wasn't in CVS).  Since
> it hasn't been generated (by building the SWIG bindings) it blow up on
> make dist.  Same is going to be true for the .cxx files.
> A few choices, which have been discussed previously:
> * make needs to build the SWIG bindings, then make dist would work
> * these files get added to SVN, so make dist works whether or not you
> build the swig bindings.  It also means you could compile the SWIG
> binding without having SWIG.
> * these files don't get added to SVN and don't get distributed, thereby
> forcing anyone who downloads GEOS to have SWIG in order to build the
> SWIG bindings.
> I'd prefer the 2nd choice.  What do other think?
> Charlie
> Mateusz Loskot wrote:
>> Paul Ramsey wrote:
>>> The deed is done.
>>> http://svn.refractions.net/postgis
>>> http://svn.refractions.net/geos
>> I'd like to confirm:
>> - clean checkout - works
>> - autogen.sh/configure - works
>> - make - works
>> - make check - works
>> - make dist - does not work
>> Here is the error message I get when running 'make dist':
>> make[2]: Entering directory
>> `/home/mloskot/dev/geos/_svn/geos/swig/python'
>> make[2]: *** No rule to make target `geos.py', needed by `distdir'.
>> Stop.
>> make[2]: Leaving directory `/home/mloskot/dev/geos/_svn/geos/swig/python'
>> make[1]: *** [distdir] Error 1
>> make[1]: Leaving directory `/home/mloskot/dev/geos/_svn/geos/swig'
>> make: *** [distdir] Error 1
>> Best regards
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
