[geos-devel] SVN Access failed - updating SWIG bindings
Paul Ramsey
pramsey at refractions.net
Thu Jul 27 11:00:48 EDT 2006
Found the problem. The postgis and geos developers are now managed in
different lists, but I had the geos reposistory still using a postgis-
developers access control list.
On 26-Jul-06, at 10:57 PM, Charlie Savage wrote:
> Okay, I have the swig generated wrapper files. But it seems like I
> can't update the new SVN repository:
> svn commit -m Added SWIG generated wrapper files for Ruby and
> Python python/geos.py python/geos_wrap.cxx ruby/geos_wrap.cxx --
> username csavage --password ****** --non-interactive
> svn: Commit failed (details follow):
> svn: CHECKOUT of '/geos/!svn/ver/1795/trunk/swig/python':
> authorization failed (http://svn.refractions.net)
> Thanks,
> Charlie
> Mateusz Loskot wrote:
>> Paul Ramsey wrote:
>>> The usual issues apply to putting generated files into the
>>> repository:
>>> if different people with different swigs generate these files
>>> they will
>>> potentially clobber each other in the repository and even generate
>>> conflicts.
>>> A checks out
>>> B checks out
>>> A generates and updates and commits
>>> B generates and updates, conflict!
>> Yes, this is the same situation as keeping ./configure script in the
>> repo and then every run of autogen.sh will introduce problems.
>> If geos.py is generated file, then 'make dist' could operate this
>> file optionally, depending on SWIG wrappers are build or not.
>> Best regards
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
