[geos-devel] OverlayOp::DIFFERENCE
Howard Butler
hobu at iastate.edu
Sun Jun 4 23:50:45 EDT 2006
Mateusz and strk,
I was working on building some makefiles for windows of xmltester,
and I ran into an issue that is confusing. MSVC 2003 doesn't seem to
like line 563 of XMLTester.cpp, complaining about not finding a
constructor:
cl -I../../source/headers /MD /GR /O2 /D "NDEBUG" /nologo /D
"NOMINMAX"
/D "WIN32_LEAN_AND_MEAN" /D "NOGDI" /GX /c XMLTester.cpp /FoXMLTester.obj
XMLTester.cpp
XMLTester.cpp(563) : error C2589: 'constant' : illegal token on right
side of ':
XMLTester.cpp(563) : error C2143: syntax error : missing ')' before '::'
XMLTester.cpp(563) : error C2512:
'geos::operation::overlay::overlayOp::overlayO
p' : no appropriate default constructor available
XMLTester.cpp(563) : error C2059: syntax error : ')'
NMAKE : fatal error U1077: 'cl' : return code '0x2'
Stop.
If I change the OverlayOp::DIFFERENCE enum to be
OverlayOp::DIFFERENCE2 in both the call and the header file, things
compile fine. What's curious is that the C API also calls difference
this way and doesn't fail to compile. I'm not sure if it is some
sort of weird namespace issue. Any ideas?
Also, http://geos.builds.hobu.net is building clean for all three
architectures.
Howard
