[geos-devel] python.i doesn't exist... why?
Charlie Savage cfis at savagexi.com
Mon Jun 5 23:24:13 EDT 2006
For a bit more info, but with a Ruby bent, I put this online:
http://cfis.savagexi.com/articles/2006/04/12/ruby-bindings-for-geos.
If I get a chance, I'll put some info together for the Python module also.
Charlie
Charlie Savage wrote:
> Hi Pablo,
> Sorry not to respond sooner - I just got back from vacation.
> What python.i is used for is to generate geos_wrap.cxx using SWIG.  If
> you look, you'll see that file exists.  So theory you could get by
> without python.i and just run the part of the build script that
> builds/installs the extensions.
> However, there unfortunately there is a problem with that because the
> geos_wrap.cxx file includes pointers to a method called readHex which
> does not actually exist in geos 2.2.2 (well, it does in my version but
> no release version).
> So I'd recommend:
> Create python.i in your swig/python directory.  Then put this code into it:
> %template(vector_GeometryP) std::vector<geos::Geometry *>;
> %template(vector_LineStringP) std::vector<geos::LineString *>;
> %template(vector_PolygonP) std::vector<geos::Polygon *>;
> Then make sure you have swig 1.3.29 installed.  Then try the build
> script again.  You may also want to delete geos_wrap.cxx before you start.
> Hope this helps,
> Charlie
> Pablo Souza Grigoletti wrote:
>> Hi people,
>> As nobody answers my question... I want to know if:
>> - Nobody knows the answer?
>> - Nobody wants to answer?
>> - Or nobody undestands me?
>> Best regards
>> Pablo
>>> Hello people,
>>> My name is Pablo, I'm Brazilian.
>>> I'm trying to compile a Python version of GEOS.
>>> To do this I'm using:
>>> - geos-2.2.2
>>> - swig-1.3.29
>>> - Debian GNU/Linux
>>> I did ./configure, make, make install... no problems in this part.
>>> So, geos was installed OK.
>>> So, I had tu use the swig (it's already installed) to do the Python
>>> version. But when I used it, I need the file python.i.
>>> I want to know why the file ruby.i exists and the python.i doesn't?
>>> The following lines on geos.i include this file (python.i):
>>> #ifdef SWIGPYTHON
>>> %include ../python/python.i
>>> #endif
>>> What can I do?
>>> Thanks,
>>> Sorry by my terrible English.
>>> Pablo
>> _______________________________________________________ Navegue com o
>> Yahoo! Acesso Grátis, assista aos jogos do Brasil na Copa e ganhe
>> prêmios de hora em hora! http://br.yahoo.com/artilheirodacopa/
>> geos-devel mailing list
>> geos-devel at geos.refractions.net
>> http://geos.refractions.net/mailman/listinfo/geos-devel
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060605/478ccb1b/smime.bin
