[geos-devel] python.i doesn't exist... why?
Charlie Savage
cfis at savagexi.com
Tue Jun 6 18:16:22 EDT 2006
Yeah, was planning on doing that. What's the timeframe you're looking at?
I did a pretty big update for GEOS 3.0 about 2 months ago, but I imagine
things have changed a lot since then. So it might take a bit of time to
get right. Having the new unit tests around helps for sure though (can
copy them to Ruby/Python as needed).
Charlie
strk at refractions.net wrote:
> Since we're talking about this, I'm in the process of closing
> up the 3.0.0 release. Charlie, could you give the swig/ bit
> a check ? If things get complicated we can rollback to the 2.x
> way of only distributing files with no attempt to automatically
> build.
> --strk;
> On Mon, Jun 05, 2006 at 11:58:25PM -0600, Charlie Savage wrote:
>> Hi Pablo,
>> Ok - that's because the swig files assume there is a readHex method.
>> This will be fixed for 3.0, sorry about the problems in 2.2.0.
>> Anyway, to manually fix open geos.i in the swig directory:
>> 1. Comment out line 166 which is:
>> %newobject WKBReader::readHEX;
>> 2. Comment out line 186-190:
>> %factory(geos::Geometry * geos::WKBReader::readHEX, geos::Point,
>> geos::LinearRing, geos::LineString,
>> geos::Polygon,
>> geos::MultiPoint,
>> geos::MultiLineString,
>> geos::MultiPolygon,
>> geos::GeometryCollection);
>> 3. Comment out lines 297 to the end of the file:
>> %extend geos::Geometry {
>> static geos::GeometryFactory& factory()
>> static geos::GeometryFactory factory;
>> return factory;
>> static geos::WKBReader& reader()
>> #if GEOS_VERSION_MAJOR == 2
>> static geos::WKBReader reader(geos_Geometry_factory());
>> #else
>> static geos::io::WKBReader reader(geos_Geometry_factory());
>> #endif
>> return reader;
>> static Geometry* fromWKT(std::string wkt)
>> std::stringstream in(wkt);
>> return geos_Geometry_reader().read(in);
>> static Geometry* fromHEX(std::string hex)
>> std::stringstream in(hex);
>> return geos_Geometry_reader().readHEX(in);
>> Thanks,
>> Charlie
>> Pablo Souza Grigoletti wrote:
>>> Hi Charlie,
>>> I did what you said:
>>> - mv geos_wrap.cxx geos_wrap.cxx.old
>>> - I created python.i with the code that you gave me.
>>> - swig -c++ -python -modern -o geos_wrap.cxx ../geos.i
>>> ../../source/headers/geos/geom.h:671: Warning(509): Overloaded
>>> geos::CoordinateS equence::hasRepeatedPoints(geos::CoordinateSequence
>>> const *) is shadowed by hasR epeatedPoints() const at
>>> ../../source/headers/geos/geom.h:658.
>>> ../../source/headers/geos/geom.h:684: Warning(509): Overloaded
>>> geos::CoordinateS equence::minCoordinate(geos::CoordinateSequence *) is
>>> shadowed by minCoordinate( ) const at
>>> ../../source/headers/geos/geom.h:661.
>>> - python setup.py build
>>> geos_wrap.cxx: In function 'geos::Geometry*
>>> geos_Geometry_fromHEX(std::string)': geos_wrap.cxx:4417: error: 'class
>>> geos::WKBReader' has no member named 'readHEX' geos_wrap.cxx: In
>>> function 'PyObject* _wrap_Geometry_srid_set(PyObject*, PyObjec t*)':
>>> geos_wrap.cxx:24176: warning: passing 'double' for argument 1 to
>>> 'virtual void g eos::Geometry::setSRID(int)' error: command 'gcc' failed
>>> with exit status 1
>>> As you said me, a problem with readHEX happened.
>>> do you have any suggestion?
>>> Ahh, I have the SWIG right version:
>>> # swig -version
>>> SWIG Version 1.3.29
>>> Best regards.
>>> Pablo
>>> On Mon, 05 Jun 2006 21:21:17 -0600
>>> Charlie Savage <cfis at savagexi.com> wrote:
>>>> Hi Pablo,
>>>> Sorry not to respond sooner - I just got back from vacation.
>>>> What python.i is used for is to generate geos_wrap.cxx using SWIG. If
>>>> you look, you'll see that file exists. So theory you could get by
>>>> without python.i and just run the part of the build script that
>>>> builds/installs the extensions.
>>>> However, there unfortunately there is a problem with that because the
>>>> geos_wrap.cxx file includes pointers to a method called readHex which
>>>> does not actually exist in geos 2.2.2 (well, it does in my version but
>>>> no release version).
>>>> So I'd recommend:
>>>> Create python.i in your swig/python directory. Then put this code
>>>> into it:
>>>> %template(vector_GeometryP) std::vector<geos::Geometry *>;
>>>> %template(vector_LineStringP) std::vector<geos::LineString *>;
>>>> %template(vector_PolygonP) std::vector<geos::Polygon *>;
>>>> Then make sure you have swig 1.3.29 installed. Then try the build
>>>> script again. You may also want to delete geos_wrap.cxx before you
>>>> start.
>>>> Hope this helps,
>>>> Charlie
>>> _______________________________________________________
>>> Abra sua conta no Yahoo! Mail: 1GB de espaço, alertas de e-mail no
>>> celular e anti-spam realmente eficaz. http://mail.yahoo.com.br/
>>> geos-devel mailing list
>>> geos-devel at geos.refractions.net
>>> http://geos.refractions.net/mailman/listinfo/geos-devel
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060606/a8c2a49b/smime.bin
