[geos-devel] Swig Update and questions
    Sean Gillies
    sgillies at frii.com
    Sat Jun 24 20:40:42 EDT 2006
On Jun 24, 2006, at 6:02 PM, Charlie Savage wrote:
>> We surely want them distributed. We also want to distribute the
>> generated
>> wrapper (for those not having unstable swig installed).
>> Would be nice if make maintainer-clean would get rid of the latter
>> and next make would recreate it.
>> (haven't tested your new makefiles yet)
> Okay, so I need to add in a hook for make maintainer-clean then and
> to have make check to see if the generated wrapper exists or not
> and create if needed (I think the makefiles already do that actually).
> Anything I need to do for getting the files into the distribution?
> Haven't checked in my changes yet, I want to first test them some
> more.
>>> * Who owns the geometries returned from methods such as
>>> Intersection, Difference, etc?  The C API doesn't give any
>>> indication and it wasn't obvious to me looking through the C++ code.
>> A rule of thumb for the C API is:
>> Every Geometry caller should take care of is returned
>> as a non-const object.
>> For these specific case the caller must delete them.
> Okay, so the caller needs to delete the results of methods like
> Intersection.  Assumedly the same goes for using the C++ api - i.e,
> geom->intersects(someOtherGeom)?
> While on the subject, I've taken a look at what would be involved
> with having the SWIG wrappers use the C api.  Its doable -
> basically I would have SWIG create "fake classes" which look like
> classes to Ruby/Python but underneath use the C API.  This is how
> the GDAL swig bindings are implemented, so its ok.  It is a bit
> silly (duplicate definitions), but it works.
> But the thing that holds me back is that in the c-api all the
> geometry types get merged into just Geometry (no points,
> linestrings, etc.). That might be ok for C, but me would seem very
> strange in Ruby or Python.  I've thought its too high too high a
> price to pay and thus
> But I wonder if there is a way around this by using a variation of
> the PIMPL idiom (http://www.gotw.ca/publications/mill05.htm)?
> Something like forward declare all the Geos geometry classes, but
> of course don't call any methods on them.  Then for any C-API
> method that returns a geometry do a dynamic_cast to see what it is
> and then return an appropriate SWIG wrapper classes.
> Sean or Hobu - didn't one of you write your own bindings for Python
> not using SWIG?  How did you handle this?  Are you happy with just
> having a Geometry object and you have to make sure to use it
> correctly (if its a point don't call NumRings)?  Or did you do
> something more clever?
Charlie,
I'm doing something similar to your idea above. When a generic
geometry is returned from a method, I check the GEOS type and then
change the class of the result object to Point, LineString, etc.
> In the end though I wonder if there is any real benefit to using
> the C api for the swig bindings. The c-api is supposed to insulate
> a program from changes to the underlying C++ api.  But the bindings
> libraries already do that.  Python/Ruby will dynamically load the
> bindings and install the appropriate classes/methods.
> That means can install a new version of GEOS, swap out the bindings
> library, restart your program, and all should be well as long as
> you haven't removed any methods (it doesn't matter if methods or
> classes or changed namespaces or changed hearder files or
> whatever).  Now if you swapped out the version of GEOS and not the
> bindings, then you'd run into problems (but you would also with the
> C-API).
> There is also the point that everything is statically linked on
> Windows  (since geos doesn't export any functions), so it doesn't
> matter at all if the version of geos is changed on the machine.
> You could do the same on Linux/Unix I suppose.
> Well, after all that rambling I've talked myself back into the idea
> that the SWIG bindings should stick with the C++ api because the C
> api provides no forward compatibility benefit (it does provide
> benefit, or disadvantage depending on your viewpoint, of a much
> smaller API).  But I'm more than happy to listen to counter
> arguments and do the work to switch over to the C api if its
> demonstrably better.
> Charlie
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
Sean Gillies
http://zcologia.com
