[geos-devel] Some C API Issues
Charlie Savage
cfis at savagexi.com
Sun Jun 25 00:21:03 EDT 2006
Some issues with the c api.
1. It looks like GEOSCoordSeq_getOrdinate is missing a coordinate
sequence as its first parameter.
RCS file: /home/cvs/postgis/geos/capi/geos_c.cpp,v
retrieving revision 1.24
diff -u -r1.24 geos_c.cpp
--- capi/geos_c.cpp 5 Jun 2006 15:36:34 -0000 1.24
+++ capi/geos_c.cpp 25 Jun 2006 02:59:02 -0000
-extern "C" int GEOS_DLL GEOSCoordSeq_getOrdinate(unsigned int, unsigned
int, double *);
+extern "C" int GEOS_DLL GEOSCoordSeq_getOrdinate(CoordinateSequence *,
unsigned int, unsigned int, double *);
2. There is an enum GEOSGeomTypeId in geos_c.h but also a method with
the same name. This makes VC++ 2005 unhappy. Can the enum be renamed
to something like GEOSGeomTypes?
3. You can get an Envelope from a Geometry, but its returned to you as
a GEOSGeom. But an Envelope is not a geometry. If you get one, and
then use it some of the methods like Intersects, won't things blow up?
Also, in my existing code I make use of a fair bit of the Envelope api
(width, height, etc.). Any chance this can be exposed in the C api?
Thanks,
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060624/c3956d44/smime.bin
