[geos-devel] Assertions in CoordinateArraySequence
Charlie Savage cfis at savagexi.com
Sun Jun 25 19:37:28 EDT 2006
CoordinateArraySequence has a number of assertions that check to see if
the requested index is out of bounds of the array.  If it is, then the
assertion is thrown - at least in Debug mode.
I'd guess assertions are off in Release builds (haven't checked), so a
segmentation fault would occur.
Could this be changed to exceptions?  When playing around at the command
line with Ruby or Python, its not very nice to have your application
terminate because you specify an invalid index.
The reason I can see for not doing this is the extra overhead in
checking the bounds - is that the case?  If so, are there profiling
results showing that it really is a big deal?
Thanks,
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060625/4e469262/smime.bin
