[geos-devel] C API, GEOSGeom_getCoordSeq, quick question...
Charlie Savage
cfis at savagexi.com
Mon Jun 26 00:39:24 EDT 2006
GEOSCoordSeq_create returns a pointer you need to clean up using
GEOSCoordSeq_destroy.
However, if you use the returned coordinate sequence as a parameter to
createPoint, createLineString, etc then the new geometry takes over
ownership (so you have to clean up the geometry instead).
Charlie
Stephen Lime wrote:
> Hi all: Is the coord seq returned by that function a pointer to owned
> coordinates or a new copy that
> needs to be cleaned up?
> Steve
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060625/2ceba7c3/smime.bin
