[geos-devel] Encounter Segmentation Fault with GEOS 2.2.2
Sheng Liang (SH/CBC)
sheng.liang at ericsson.com
Thu Jun 29 02:23:45 EDT 2006
Thank you.
I compared your code with mine. It is my fault. I didn't
Pass a valid notice_function and an error_function when I call
initGEOS().
Now there is no segmenation fault. But an error still happen.
The error message is :
TopologyException: no outgoing dirEdge found (125.331,0)
I can't dig into the source code of GEOS, for I don't know much about
it.
Did you encounter this error?
Regards
-----Original Message-----
[mailto:geos-devel-bounces at geos.refractions.net] On Behalf Of
strk at refractions.net
Sent: Wednesday, June 28, 2006 21:13
To: GEOS Development List
Subject: Re: [geos-devel] Encounter Segmentation Fault with GEOS 2.2.2
Ops, sorry, I fell in the initGEOS missing call myself.
Actually I can *not* reproduce the error against the 2.2 branch.
Here is my testcase, if you confirm it fails please send a backtrace, or
valgrind output.
#include <stdlib.h>
#include <stdio.h>
#include <geos_c.h>
int main()
initGEOS(printf, printf);
GEOSGeom aPolygon1,aPolygon2;
const char *aString1 = "POLYGON ((125.331 0,3.35823e-06
125.331,-125.331 6.71
646e-06,-1.00747e-05 -125.331,125.331 0))";
const char *aString2 = "POLYGON ((245.331 120,120 245.331,-5.331
120,120 -5.3
31,245.331 120))";
aPolygon1 = GEOSGeomFromWKT(aString1);
aPolygon2 = GEOSGeomFromWKT(aString2);
GEOSGeom anIntersection = GEOSIntersection(aPolygon1,aPolygon2);
--strk;
On Wed, Jun 28, 2006 at 01:51:59PM +0200, strk at refractions.net wrote:
> Oh, ok, I now remember to have fixed this in HEAD.
> Can you confirm ?
> --strk;
> On Wed, Jun 28, 2006 at 09:15:25AM +0800, Sheng Liang (SH/CBC) wrote:
> > Hi:
> > Yes. I have called initGEOS() before I create those GEOSGeom.
> > As I said, if I provide some other polygons, there is no fault.
> > The fault just happened to these two specific polygons.
> > Regards
> > From: geos-devel-bounces at geos.refractions.net
> > Sent: Tuesday, June 27, 2006 23:45
> > 2.2.2
> > Did you call initGEOS() ?
> > That's currently *required* (might change in the future)
> > --strk;
> > On Mon, Jun 26, 2006 at 12:07:48PM +0800, Sheng Liang (SH/CBC)
wrote:
> > > HI:
> > > I have tried aString1.c_str(), but I still get the same error.
> > > And I
> > > even use such code:
> > > 125.331,-125.331 6.71646e-06,-1.00747e-05 -125.331,125.331 0))";
> > > 245.331,-5.331 120,120 -5.331,245.331 120))";
> > > And the error is the same.
> > > Regards
> > > Mateusz Loskot
> > > Sent: Monday, June 26, 2006 11:49
> > > 2.2.2
> > > > Hi: I encountered an error of "Segmentation Fault" with GEOS
2.2.2.
> > > > What I am doing is to get intersection of two polygons. The
> > > > error happens to the specific polygong: POLYGON ((125.331
> > > > 0,3.35823e-06
> > > > and POLYGON ((245.331 120,120 245.331,-5.331 120,120
> > > > -5.331,245.331
> > > > 120))
> > > > There is no error to others polygons. So I think it must be an
> > > > error
> > > > of GEOS 2.2.2 code.
> > > > My code is : GEOSGeom aPolygon1,aPolygon2; string
> > > > aString1("POLYGON
> > > > ((125.331 0,3.35823e-06 125.331,-125.331
> > > > -125.331,125.331 0))");
> > > > string aString2("POLYGON ((245.331 120,120 245.331,-5.331
> > > > 120,120
> > > > -5.331,245.331 120))");
> > > > aPolygon1 = GEOSGeomFromWKT(aString1.data());
> > > > aPolygon2 = GEOSGeomFromWKT(aString2.data());
> > > I'm suer in 99% that the problem is in your code above.
> > > You should not access internal buffer of std::string with data()
> > > member function. It should be used in very rare cases because it
> > > breaks OOP rule of encapsulation! It's available only for C
> > compatibility.
> > > GEOSGeomFromWKT expects to get const char* :
> > > Geometry *GEOSGeomFromWKT(const char *wkt);
> > > so, you should call it as follows:
> > > aPolygon1 = GEOSGeomFromWKT(aString1.c_str());
> > > std::string::c_str() returns const char*.
> > > Cheers
> > > Mateusz Loskot
> > > http://mateusz.loskot.net
> > > _______________________________________________
> > > geos-devel mailing list
> > > geos-devel at geos.refractions.net
> > > http://geos.refractions.net/mailman/listinfo/geos-devel
> > /"\ ASCII Ribbon Campaign
> > \ / Respect for low technology.
> > X Keep e-mail messages readable by any computer system.
> > / \ Keep it ASCII.
> / \ Keep it ASCII.
/ \ Keep it ASCII.
