[geos-devel] Robustness of Binary Predicates
Todd Jellett todd.jellett at caris.com
Wed Mar 1 11:43:35 EST 2006
Hi all,
I have a question concerning the robustness of the Binary Predicates
(disjoint, contains, etc.). I see on the JTS site that they are claimed
to be "completely robust" but I don't see anywhere where the "extraneous
(secondary) intersection points created from snapping the primary
intersection points" are detected and processed when using a FIXED
precision model. The monotone chains only find the primary intersection
points.
Here is an example which creates "extraneous intersection points".
From:    John D. Hobby, "Practical Segment Intersection with Finite
Precision Output", Comput. Geom Theory Appl., 13:199-214, 1999
Use precision model with a scale of 1 to setup a FIXED precision model
with 1 significant figure (Whole Numbers).
LINESTRING (-1.0 -2.0, 9.0 5.0, 0.0 0.0, 13.0 6.0)
LINESTRING (9.0 4.0, 5.0 3.0)
The first LineString consists of 3 segments of which 2 of these segments
intersect at (5.45,2.52). This intersection point "should" then be
snapped to the precision model giving (5.0,3.0). Snapping this
intersection point causes the point to move to the other side of the
middle segment of the LineString which in turn causes 2 extra
intersection points to be created ( (4.0,2.0) and (6.0, 3.0) when snapped).
In this particular case it is not these 2 extraneous intersection points
that are causing me to question the robustness of the Binary Predicates,
instead it is the *not snapping of the primary intersection point* by
the Binary Predicates..
This sets up ambiguities such as disjoint = true and touches = false but
intersection = MULTIPOINT (5.0 3.0, 6.0 3.0, 8.0 4.0).
Should be POINT (5.0 3.0) shouldn't it?
I realize that the final robustness issues of the intersection, union,
etc. are just being addressed, but to get the 2 sets of operations to be
consistent and only address robustness issues of the intersection,
union, and differences, won't it mean that you will have to ignore real
nodes and edges in the graph when computing one of these? Wouldn't this
defeat the whole purpose of the graph(s)? How could this work without
ambiguities?
The Binary Predicates seem to "almost be working at infinite precision".
Shouldn't both the predicates and the set theoretics *both* be operating
at the precision of the precision model provided?
Note: These extra intersection points can occur even if the precision
model is FLOATING (ie FIXED with 15 significant figures).
Let me know if any of this is not clear.
I used geos 2.2.0 for my tests.
Todd
