[geos-devel] truncated buffer result
    Pierre GIRAUD
    bluecarto at gmail.com
    Thu Mar  9 08:09:46 EST 2006
Hello,
I probably found a tiny issue in the buffer computation on a POYGON shape.
Using Mapserver geos implementation, I fell on a curious behaviour of
the buffer compuation (see attached image).
To reproduce the bug, I tried a similar request in PostGIS, and
obtained the same result. So I suppose this is a GEOS library issue.
psql -d database -c "SELECT
astext(buffer(geometryfromtext('POLYGON((663194 796327,663281
1796368,663226 1796300,663194 1796327.1,663194 1796327))'), 50));"
Do I have to fill in a bug ?
Regards
Pierre GIRAUD
Type: image/gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060309/01370454/1141835200104121.gif
