[geos-devel] truncated buffer result
Pierre GIRAUD
bluecarto at gmail.com
Fri Mar 10 06:49:09 EST 2006
Hum it works.
Note : the documentation doesn't match ?
IsSimple(geometry)
Returns 1 (TRUE) if this Geometry has no anomalous geometric
points, such as self intersection or self tangency.
Performed by the GEOS module
OGC SPEC s2.1.1.1
On 3/10/06, strk at refractions.net <strk at refractions.net> wrote:
> On Fri, Mar 10, 2006 at 10:47:13AM +0100, Pierre GIRAUD wrote:
> > Hum, I didn't check that because it wasn't expected for those data.
> > I feel embarrassed because issimple on this geometry returns true.
> > SELECT issimple(geometryfromtext('POLYGON((663194 1796327,663281
> > 1796368,663226 1796300,663194 1796327.1,663194 1796327))'));
> You should use isvalid() instead.
> --strk;
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
